Jun 1, 2024 Admin #2 Mike Phillips Administrator Staff member Joined May 21, 2021 Messages 2,021 Reaction score 1,109 Points 113 Location Stuart, Florida Website themikephillipsforum.com Nice video. For those headlights, I would MACHINE sand with 3" Mirka Abralon sanding discs on a 3" backing plate. #500 #1000 #2000 Then rotary buffer with wool pad. Follow with foam pad on DA. Seal This approach works fast and awesome. See pictures of machine sanding headlights here, 564 Pictures - May 3-day class at Dr. Beasley's O.R. in Stuart Florida with Mike Phillips The trick is to use 2-3 foam interface pads between the backing plate and the sanding disc to avoid gouging the plastic. Mike
