Best Polishers for Beginners?
Polisher options for beginners
The good news is, there are a LOT of options when it comes to machine polishers for beginners when doing paint correction. The bad news, there are so MANY options when it comes to polishers and buffers that it can be very confusing.
Budget friendly
The price for a car polisher ranges from under $100.00 up to $800.00 - that’s a very wide spectrum of pricing options.
Under $200.00
We’ll be looking at polishers that range between $65.00 to $170.00. There may be a few polishers available at discount stores that cost under our low price point of $65.00 but from experience, at this price point, these tools don’t have the power to enable you to de-swirl an average size passenger car in a time-efficient manner. Time is money and when it comes to power tools, the old adage rings true - you get what you pay for.
Order of review
Below are the polishers we’ll be looking at and their prices at the time this article was written from the lowest price to the highest price. I will also go over free spinning orbital polishers first as these all operate in the same way. After free spinning polishers, I’ll go over the least expensive gear-driven orbital polisher on the market at this time.
Free Spinning Random Orbital Polishers
BAUER 5.7 Amp 6 in. Short-Throw Random Orbit DA Polisher/Sander - $64.99
PORTER-CABLE 7424XP Car Polisher and Buffer, 6-Inch, Orbital, Variable Speed - $139.00
Griot’s Garage G9 Random Orbital Polisher - $169.99
Optional - Best budget mini polisher for buffing out thin panels and curved panels
Griot’s Garage G8 Mini Random Orbital Polisher - $144.99
Best Budget Gear-driven Orbital Polishers
HERCULES 8 Amp 6 in. Forced Rotation Dual-Action Polisher - $119.99
First up, my recommendation for an absolute newbie.
Pros
Powerful for an 8mm orbit stroke
Inexpensive
Compact size
Can use different size backing plates
Cons
Vibrates your hands
Noisy out of the box
Like all free spinning random orbital polishers - you must constantly monitor for pad stalling
Technical
8mm orbit stroke
Speed - 2000 to 6400 OPM
6 speed settings
10’ Power Cord
120 Volts
5.7 Amps
5.6 pounds
5/16” UNF Fine Thread
Two position auxiliary handle (left and right)
Power lock slide switch
6” hook and loop backing plate
My comments
This is easily the best bang for your buck when it comes to a cheap, free spinning random orbital polisher. This is a knock-off of the once very popular Porter Cable 7424XP. It costs around half as much as a Porter Cable 7424XP but has a LOT more power.
Some people complain that it has too much vibration and is too loud under full speed operation. This can be improved by removing the factory grease and replacing it with a premium quality lithium grease, which I’ll share in a separate article/video.
Like the Porter Cable 7424XP, the Bauer polisher when compared to most other polishers is compact in size making it easy to use anywhere on the car. It’s easy to grip with both hands and if needed, it can be held with just one hand, for example, machine applying a wax.
The 8mm orbit stroke length is perfect for removing swirls and scratches and because this is a SHORT stroke polisher, it’s a lot easier to maintain good pad rotation compared to long stroke polishers. Maintaining pad rotation and pad oscillation is crucial for fast and effective defect removal and this is important for anyone that is new to machine polishing.
With the 5/16 fine thread spindle, you can attach different size backing plates for example, 6”, 5” and 3” backing plates.
The smaller 3” backing plate enables you to use 3.5” and 4” buffing pads and this works better for buffing thin panels, (to avoid buffing on top of raised body lines or edges), and also works better for buffing inside concave curved body panels.
The only downside to a 3” backing plate and thus the smaller pad is it makes the tool tippy. By the word tippy I mean, the tool body itself is much larger than the small 3.5” buffing pad so you have this larger tool, over the top of a small spinning pad and it simply makes the tool tippy. When using a small backing plate and small buffing pad, you definitely want to have a strong grip on the tool and control the buffing pattern.
The factory 6” backing plate in my opinion is too large as this forces you to use larger 6.5” and 7” buffing pads and the diameter size and thickness of pads this size tends to absorb a lot of the energy coming out of the tool and dissipate it. This shows up as weak or anemic pad rotation/oscillation.
The optimum backing plate size is 5” as this allows you to use 5.5” buffing pads and this size is the best all-around size for maintaining great pad rotation/oscillation for the most time effective defect removal.
This tool comes with a side handle, also called a stick handle, and it can be attached on either side of the head of the tool. My strong recommendation is to simply throw the handle away because when newbies just starting out use the handle, they tend to push harder on the handle, and this causes the pad to press against the body panel at an angle.
Holding the tool and thus the pad against the surface at an angle decreases pad rotation/oscillation. What works better to maintain good pad rotation/oscillation is to place one of your hands on the head of the polisher with your other hand on the body of the tool. With these hand positions, it’s dramatically easier to maintain EVEN pressure on the head of the tool and thus maintain the pad flat to the surface.
Besides using this tool for paint correction, you can also use it for sanding wood, car paint and gelcoat boats. While not super effective, you can also attach scrub brushes to the tool or the backing plate and use this to machine scrub surfaces.
Recommendation
If you’re brand new to detailing, this is a great entry level tool. You can gain a lot of experience doing paint correction with this tool and as you gain experience and confidence you can decide if this is all the polisher you need, or add a new, more powerful tool to your detailing arsenal.
With an average retail price of $65.00, and even cheaper if you purchase during a sale, this is a very low-cost way to get into car detailing and paint correction. If you do purchase this tool, I strongly recommend spending the extra money you save and purchase a 5” backing plate. A 5” backing plate that fits this tool can be easily found on Amazon.
If you don’t get the 5” backing plate, you are forced to invest your pad money into 6.5” and larger buffing pads and at some point, you’ll learn I am correct about the smaller 5” backing plate and 5.5” buffing pads being a better fit for this type of tool. If you make the switch later, all the money you spend on larger pads is more or less wasted. So, get the smaller 5” backing plate and right from the start, invest you pad money into smaller and even thinner buffing pad for optimum pad rotation/oscillation.
What about the long stroke Harbor Freight polisher?
Great question. In the video that goes with this article, I cover this tool and recommend NOT starting with this tool. I included it in this article and the video because I know some of you, after reading this article and/or watching the matching video, will head down to Harbor Freight to check out the above Harbor Freight 6” Short Throw DA Polisher and you’ll SEE this tool, the BAUER 7.5 Amp, 6 in. Long-Throw Random Orbit DA Polisher.
BAUER 7.5 Amp, 6 in. Long-Throw Random Orbit DA Polisher - $79.99 - NOT RECOMMENDED
As I state in the video, long stroke orbital polishers take more technique and practice to maintain good pad rotation and pad oscillation. Large stroke and large pads are great for large flat surfaces, like the roof, but most cars have a lot of body designs and curves, and this is where you will struggle to maintain pad rotation.
It’s MUCH easier to maintain good pad rotation/oscillation with a short stroke polisher than a long stroke polisher. This is why in this list of free spinning random orbital polishers, I put the focus on all short stroke polishers. I did want to reference this because I know you’re going to see it and have questions.
I go more into the details as to why I don’t recommend any brand of long stroke free spinning random orbital polishers for beginners in the video - if you want more information. And just to add, the BAUER 7.5 Amp, 6 in. Long-Throw Random Orbit DA Polisher is a 20mm orbit stroke.
Pros
Decades of proven quality and reliability
Safe entry level tool
Can use multiple backing plates
Use for paint correction, sanding, scrubbing
Lightweight, compact size
Cons
The weakest polisher in this list of polishers
Poor quality electronic speed adjustment dial
Technical
8mm Orbit Stroke
Speed - 2,500 to 6,800 OPM
6 speed settings
10’ Power Cord
120 Volts
4.5 Amps
5.5 pounds
One-time use backing plate and pad combination
My comments
Sometime in the 1980’s, both Meguiar’s and Griot’s Garage introduced the Porter Cable wood sander as a paint polisher for the car detailing world. While there are a lot of dual action wood sanders in the construction industry, it is the Porter Cable dual action sander that had enough power to also rotate and oscillate a buffing pad.
The introduction of the Porter Cable dual action polisher or PC as it is referred to in the car detailing world, was a huge game changer. Before the PC, the three primary tools available were,
Rotary polisher
The rotary polisher takes time to learn how to correctly and safely use and too often it leaves hologram scratches in the paint for people just starting out.
Traditional orbital polishers
These tend to be large and bulky and the OPM is too slow to do any effective paint correction. Most people refer to these old types of orbital polishers as wax spreaders, because that’s really all they can be used for. They simply don’t work to remove swirls and scratches out of modern clearcoat paint systems.
The Cyclo polisher
With its dual oscillating backing plates/buffing pads, does have the power to remove swirls and scratches out of modern clearcoat paint systems, but it too is a tick on the bulky or awkward side of useability.
Plus, using a polisher with two spinning buffing pads requires the operator to continually focus on how they are moving the polisher over the finish in order to be thorough when it comes to removing paint defects. I say this with great respect for this tool and would like to point out that I’m pretty sure I’m the ONLY car detailing instructor in the detailing world with PHOTO-DOCUMENTED write-ups for my Cyclo classes. And in these classes you’ll see 20 people all using the Cyclo polisher on huge, cool cars at the same time. I challenge anyone to find any other all-Cyclo class fully photo-documented.
The average price of the tool by itself at $360.00, this also puts it out of reach for a lot of weekend warriors. And then you have to purchase multiple buffing pads to feed it.
Before Harbor Freight knocked the PC off, the PC was the go-to free spinning random orbital polisher in both the enthusiast and professional detailing world. It doesn’t have the same power as the Harbor Freight version and when it comes to this type of tool, you really want all the power you can get to help you to maintain pad rotation/oscillation.
The other thing I don’t like, and a lot of other people don’t like about the PC is the electronic variable speed dial. With most variable speed dials, as you turn the dial to change the speed setting you can feel and hear the motor speed increase or decrease. With the PC, there’s very little difference between the 1, 2 and 3 speed settings. You can feel and hear an increase in speed when you turn the dial from one of these lower speed settings to the 4, 5 and 6 speed settings. It’s not a huge deal, but it seems like a simple fix that Porter Cable could implement if they wanted, but they choose not to do so. And yes, I have spoken to a key engineer at Stanley Black & Decker, the company that owns Porter Cable.
I like the quality fit and finish of the tool itself. I also like the compact size and lightweight. I think it runs smoother, that is less vibration than the Harbor Freight knock-off but the difference in vibration isn’t enough to make a person choose it over the Harbor Freight version.
The PC has a stellar reputation for being an absolute TANK for a tool. You could drive over this with a truck and pick it up off the ground and go right back to work with it. The thing simply won’t die. The compact size and weight, and overall smoothed over tool body makes it easy to hold, maneuver and use for hours.
I’ve personally used a PC to not only buff out hundreds of cars over the decades but also to machine sand paint to remove orange peel as well as machine sand gelcoat boats to remove severe and deep oxidation and also dock rash.
Recommendation
I hate to say this, but if you’re contemplating either the Harbor Freight or the Porter Cable as your first car polisher, I would recommend the Harbor Freight 6” DA Polisher over the Porter Cable 7424XP. The extra power you get with the Harbor Freight version of the PC makes it much easier for the average person and especially a newbie to maintain pad rotation/oscillation and this is the most important aspect about ANY type or brand of free spinning random orbital polishers.
Take the money you save buying the Harbor Freight 6” DA Polisher and purchase a 3” and 5” backing plates and pads to fit both backing plates. If you don’t like the noise and vibration, remove the factory greatest in the head unit and replace it with a top-quality brand of lithium grease.
Pros
Well-built, quality polisher. The team at Griot’s Garage really did a great job creating a user-friendly, power tool. I personally know some of the people behind the design and creation of the BOSS tools and they are all solid, high-caliber people with years of real-world detailing experience. We’re not talking about marketing people; we’re talking about getting-your-hands-dirty and doing the work to detail cars for decades.
Their opinions and ideas matter and Richard Griot and his son Nick listened to the input of my friends Jeff Brown, Rod Kraft as well as the rest of their team and the end results are pro-quality tools you can trust to get the job done and last for a lifetime. If they ever do break, Griot’s stands behind their products with a lifetime guarantee.
In my opinion, for most people and certainly for everyone new to detailing and specifically paint correction, short stroke random orbital polishers like the Griot’s G9, which is a 9mm orbit stroke polisher, are a wiser choice than their counterparts, long stroke free spinning random orbital polishers.
Why?
Because it’s easier to maintain good pad rotation with a short stroke polisher versus a long stroke polisher. It has to do with the outer edges of a spinning buffing pad and the leverage the outer edges have over the spindle that spins the backing plate. The larger the stroke, the larger the pad, the more leverage the pad has over the driving force that rotates and oscillates the pad.
Conversely, the shorter the stroke and the smaller the pad, the less leverage the outer edges of a spinning buffing pad has over the spindle. Thus in a world where there is a lot of focus on long stroke polishers, the fact that Griot’s continues to offer a quality short stroke polisher shows they know all this stuff too well.
The G9 in the tool name stands for a 9mm orbit stroke length. This is only 1mm larger than the Porter Cable polisher they introduced to the enthusiast and pro detailing world back in the 1980s. It’s also only 1mm larger than the infamous GG6, which was the Griot’s version of the Porter Cable that sold for years if not decades. The GG6 or Griot’s Garage 6” Dual Action Polisher would have been more aptly named the GG8 as the number 8 stands for 8mm, which was the orbit stroke for this tool. Like a lot of companies, back when Griot’s was offering the GG6, it was named thusly because it came with a 6” diameter backing plate.
As previously discussed, the size of the backing plate, while important, has nothing to do with the action of the tool. That’s all in the rearview mirror now and you can see by the current naming protocols, Griot’s now names their tools by the action of the tool, not the size of the backing plate.
The 9mm orbit stroke length is the perfect balance between too small and too large for beginners. 9mm orbit stroke length offers plenty of correction ability to remove swirls, scratches, water spots and oxidation while also being easy to maintain great pad rotation/oscillation.
The tool itself is ergonomic in its design with plenty of built-in features to make this a best-in-class polisher for both beginners and professionals alike.
Cons
In the context of all competing short stroke free spinning random orbital polishers, for price, power, functionality and value, there are no cons.
Technical
9mm orbit throw
Powerful 1000-watt, 8.5-amp motor
Fan-cooled counter-balance (patent pending)
Premium bearing construction
Fitted with 6" Vented Orbital Backing Plate
2000 to 6400 orbits per minute
10-foot quick-connect 18 AWG SJO rubber power cord
6 speed settings
Speed dial accessible for right- and left-hand users
Constant speed control
Shroud grip contoured to accommodate four fingers
Rest pads for tool to lay stable on its back
Quick access brush side ports
Includes 14mm backing plate wrench, and replacement high-carbon brushes
Convertible to a 5" pad system with optional 5" Vented Orbital Backing Plate
Double-shot rubber platypus head-grip, as well as double shot rubber platypus strategically placed all over the tool.
My comments
I still have one of the first G9s available in the U.S. market given to me by my long-time friend at Griot’s Garage, Doug Hodge, (since retired). It still works just as well as the day I was given it back in September of 2019.
It’s smoother and more powerful than both the Harbor Freight 6” DA and the Porter Cable 7424XP at a price point that’s only a few dollars more than the Porter Cable 7424 but still under $200.00 And with the lifetime guarantee and industry setting proactive customer care, it’s really a great value for your hard-earned dollars.
Besides the tool, Griot’s also offers a complete line of microfiber and foam buffing pads in sizes that fit all the Griot’s Garage polishers and backing plates, which are purpose-tuned to their tools.
Recommendation
If you’re looking for a great, all-purpose free spinning, random orbital car polisher that won’t break the bank and offers more power and a much smoother operating experience than either the Harbor Freight or Porter Cable short stroke polishers, then I would wholeheartedly recommend the Griot’s G9.
Optional
Best budget mini polisher for buffing out thin and curved panels as well as tight areas and small components.
Pros
Compact size and smaller backing plates make this a great add-on to a full-size tool. The 3” backing plate enables you to turn and churn smaller 3” pads which enable you to do paint correction on both thin panels, so you don't have to risk buffing on edges and raised body lines.
There is also an optional 2” backing plate and matching pads for working the thinnest of panels and/or buffing out intricate areas and components. This smaller size tool and smaller size pads mean you can maintain pad rotation no matter what the shape of the body panel including sharp concave curves. Plus the small size makes this tool super easy to control for buffing with surgical precision.
Cons
There really are no downsides to this tool outside of the purchase prices, which is very affordable considering all this tool has to offer.
Technical
8mm orbit throw
Powerful 700-watt, 6-amp motor
Fitted with 3" Vented Orbital Backing Plate
Includes 2" Orbital Backing Plate
2000 - 6400 orbits per minute
6 speed settings
Fully variable speed trigger throttle with trigger lock
Ergonomic design dampened with double-shot rubber for supreme comfort
My comments
To me, this is really the tool to have for exactly what it’s intended to do and that's to tackle all the small stuff. I would not recommend this for your only or first polisher, but as an additional polisher to your full-size polisher.
I do know some people do in fact use this to buff out entire cars, but realistically, tackling the hood or any body panel that needs serious paint correction with a 3” pad is simply not time-efficient. That said, I also know people that have physical limitations are unable to hold and use large format tools for extended periods of time and for these people, this smaller, more compact but still easy to hold polisher might be just the solution they’ve been looking for.
Recommendation
Because of the quality design, power and performance, I would wholeheartedly recommend this tool for anyone’s detailing tool collection. There’s an old saying that goes like this,
Use the right tool for the job
When you need to buff out thin panels without the risk of buffing on an edge or raised body line, or anytime you’re buffing tight or intricate areas or components, the right tool for the job is the Griot’s G8. You will see what I mean about buffing out thin panels, intricate or tight areas in the video.
Pros
Zero pad stalling
Powerful swirl-free paint correction
Inexpensive
Cons
Requires more physical muscle to control and use
Longer learning curve than a simple free spinning random orbital polisher
Does not offer the 7-function microprocessor that comes standard with all FLEX polishers.
Technical
8mm orbit stroke
Speed - 3200 to 9600 OPMs
6 speed settings
25’ Power Cord
120 Volts
8 Amps
6.3 pounds
Forward bail handle
6” backing plate
My comments
As a long-time user of all the FLEX 8mm gear-driven orbital polishers, I have to say, I was impressed with this inexpensive knock-off of the FLEX XC 3401 VRG also known as the BEAST. I expected it to be inferior in every way, but I was wrong. It’s smooth, quiet and powerful. It’s a pretty exact clone of the BEAST but there are a few places they cut corners.
1: The backing plate bolt and two washers, one flat and one locking are sub-standard in quality but could easily be replaced with better components.
2: The Harbor Freight Forced Rotation Dual Action Polisher does not offer the 7-function microprocessor that comes standard with all FLEX polishers.
The FLEX 7-function Microprocessor includes,
One of the most important functions is the heat sensor, which monitors tool temperature. If the tool becomes too hot, the 7-function microprocessor will turn the tool off so no damage can occur.
Another key benefit to the 7-function microprocessor is the power interruption function. If power goes off to the tool, when power is restored, the tool will NOT turn back on until you release the speed trigger lock. This prevents the tool from turning on and possibly causing damage to a vehicle or a person.
The Harbor Freight version of the BEAST has none of these features. Besides that, this tool works as advertised.
Recommendation
If you’re a beginner, and completely new to using any type of polisher, the Harbor Freight Forced Rotation Dual Action Polisher is a handful to learn how to use and master as your first tool. I’m not saying some people are unable to do this, I’m just warning you ahead of time, it’s a very powerful tool and you’ll need to spend some time getting used to it before knowing if it’s the right tool for you.
If you’re in strong physical condition and gripping onto a polisher to control it for hours doesn’t bother you, then I would strongly recommend taking a strong look at this gear-driven polisher. The good news is, Harbor Freight has a very good warranty and excellent customer service.
Here’s the Harbor Freight Warranty,
RETURNING ITEMS PURCHASED IN STORE
If for any reason you are not satisfied with an item purchased from Harbor Freight Tools, you may return the product within 90 days for a full refund or replacement, whichever you prefer. The limited warranty term is 90-day beginning on the date of invoice. You must provide the original receipt to receive an exchange or refund.
This means, you can purchase this tool, test it out for 90 days and if you find it’s not the tool for you, simply return it. Just be sure to keep your receipt and I would suggest keeping the original box and any items that came with the tool, in the box.
Probably 60% of my paint correction work is performed with the FLEX XC 3401 VRG aka the BEAST. The other 40% is done primarily with the rotary polisher and when working on soft paint or soft plastics, a free spinning random orbital polisher like shared in the first part of this article.
So yes, I’m a huge fan of this type of tool, 8mm gear-driven orbital polishers and the Harbor Freight Forced Rotation Dual Action Polisher is an inexpensive option compared to the famous BEAST.
If you’re a professional, I would recommend investing in the actual FLEX BEAST, and another strong recommendation would be, for any tool you consider your primary tool, it’s always a good practice to have a backup of the same polisher. This way if something does go south with a tool in the middle of a detail, you’re not dead in the water.
Which polisher is the best value for the money?
Realistically, the only way to know for yourself which tool is the best bang for your hard-earned bucks is by holding them in your hand and using them on multiple cars. The downside of this plan is you will need to purchase any tool you’re interested in unless you have a buddy that has the tool you’re interested in and of course, hopefully they will let you test it out. The other option is to read through this article and let me help you to decide.
Consider taking one of my detailing classes
I teach what I consider to be the most hands-on, as well as exhaustive car and boat detailing classes on planet Earth. There are no chairs in my classes and thus ZERO sitting. Instead, you spend all your time using multiple types of tools working on cool cars and boats in horrible condition. This includes the opportunity to test out for yourself all the tools shared in this article, plus many more.
By taking one of these classes in Stuart, Florida, you get to try before you buy and just as importantly, I’ll completely flatten out the learning curve so when you leave, you’ll have confidence with all the tools and techniques popular in the detailing industry.
Which type of polisher?
There are 4 different types of tool actions,
For this article and video, we will be looking at tools from the first 2 groups, the free spinning random orbital polishers and the gear-driven orbital polishers.
Cord or no cord?
There are 2 types of power options available with modern polishers on the market today.
Corded tools - These are tools you’ll need to use with an electrical power outlet.
Cordless tools - These are battery operated tools and each year, more of this style of tool is being introduced to the marketplace.
While there are some inexpensive battery-operated, cordless polishers on the market today, the performance of the tool and the performance of the battery technology do not make these practical options. I get it, we all want a cordless tool that works great, but the price for working great is a tick higher than most beginners are willing to spend. For the scope of this article, we will be looking at traditional corded polishers.
I will be sharing a new article for cordless polishers that are worth their asking price in the near future, so subscribe to the Dr. Beasley’s Newsletter here,
Click here to subscribe to the Dr. Beasley’s Newsletter
Free spinning random orbital polishers vs Gear-driven random orbital polishers - what’s the difference?
Great question. First, notice the description for the first type of tool listed above includes the word RANDOM while the description for the second type of tool omits the word RANDOM.
Let me start by explaining what a gear-driven orbital polisher is and how it works, and this will make it easier to understand what a free spinning random orbital polisher is and how it works.
Gear-driven orbital polishers
This type of polisher has two sets of gears inside the housing at the head of the polisher. There’s an outer gear ring and there’s an inner geared backing plate. When turned on, the electric motor turns the spindle, which is directly connected to the inner geared backing plate, which in turn meshes with the outer gear ring forcing the backing plate to both rotate and oscillate with zero slippage or stalling.
To see the gears so you can see the difference between a gear-driven orbital and a free spinning random orbital polisher, I’ll remove the backing plates from both the Harbor Freight Forced Rotation Dual Action Polisher and the Porter Cable 7424XP.
This is the Harbor Freight Forced Rotation Dual Action Polisher
The tool comes with the correct size hex head wrench to remove the bolt that holds the backing plate to the spindle.
IMPORTANT
Do not lose the bolt and the washers. The bolt is the correct length to ensure the gears correctly mesh together. If you must replace the bolt, be sure to get the exact size and thread bolt from a local hardware store. Too short of a bolt and you will not have enough threads in contact with the spindle to operate the tool safely. Too long of a bolt and there will be slop or slack between the gears and you can damage the gear sets.
The inner gear set
With the backing plate removed, you can see the inner gear set on the inside of the backing plate.
Outer gear set
In the below picture you can see the outer gear set that the inner gear set meshes with when the backing plate is attached to the spindle.
Because there is zero slippage or stalling, the backing plate and thus the buffing pad will both rotate and oscillate no matter what. This includes factors like,
None of the above factors or influences to the buffing operation will affect or hinder pad rotation and pad oscillation. All of the above factors WILL affect or hinder pad rotation and oscillation of free spinning random orbital polishers.
I often see people refer to gear-driven orbital polishers and forced rotation polishers. My guess is these people are either misinformed or simply too lazy to type or say the full description for this type of tool. Harbor Freight got it right when they listed their version of the FLEX XC 3401 VRG aka The BEAST as a Forced Rotation Dual-Action Polisher. Adding the words Dual Action after Forced Rotation is technically correct as this tool offers two actions - rotation and oscillation.
When someone refers to the above type of tool using ONLY the words forced rotation, with or without knowing it, they are referring to a rotary polisher. Like the gear-driven orbital polisher, a rotary polisher is gear-driven. Thus, a rotary polisher is forced rotation and forced rotation ONLY.
When you turn the power to the ON position on a rotary polisher, the electric motor forces the backing plate to spin in a single direction aka rotation. Thus, a rotary polisher is a forced rotation polisher but a tool like the Harbor Freight Forced Rotation Dual Action Polisher is a forced rotation PLUS forced oscillation polisher. Subtle wording difference, but HUGE practical difference when using this type of tool.
Because there is no slippage between the inner and outer gear set, both the rotation and the oscillation are distinct and defined. In this case, the oscillation is 8mm. This means, the diameter of the oscillation or tiny circle is 8mm. It’s always constant, thus we don’t use the word RANDOM to describe the action of a gear-driven, orbital polisher.
Summary
A gear-driven, orbital polisher is a forced rotation, forced oscillation polisher. There is zero pad stalling. Because there is zero pad stalling, there is zero wasted time and what I call Brain Drain.
Now that we’re all on the same page as to what a gear-driven orbital polisher is and how it works, let me explain what a free spinning random orbital polisher is and how it works. With a free spinning random orbital polisher, instead of an inner and outer gear set, you have a free rotating spindle assembly connected to a counterweight.
Removing the backing plate on the Porter Cable 7424XP
Using the included Porter Cable Wrench, I slide the wrench into the spindle from the opposite side of the counterweight and then while holding the wrench, remove the backing plate via a counterclockwise motion.
With the backing plate removed, here’s what is called a free spinning or free rotating spindle assembly.
I can take my finger and easily spin the spindle freely. This same thing applies to any brand or orbit stroke of free spinning random orbital polisher. The spindles and counterweights on other brands of polishers may look different but they operate the same way.
Here’s the counterweight
When the tool is brought up to a high speed, inertia is created in the counterweight, and this causes the spindle to both rotate and oscillate. As the electric motor spins the free rotating spindle assembly and thus pad rotation and pad oscillation are maintained via the inertia created by the counterweight.
The free rotating spindle assembly is NOT directly or solidly connected to the counterweight and for this reason there is slippage.
This slippage shows up to our eyes as the buffing pad is not rotating or oscillating. And most of the time instead of seeing pad oscillation and rotation, you see the pad simply stalling out and vibrating or jiggling against the paint surface. Because of this slippage, there is no distinct and/or forced rotation/oscillation and therefore any orbital action is random.
The upside to a free spinning random orbital polisher
A lot of people new to machine polishing and with little or no experience, are afraid they are going to burn-through-the-paint. Or cause some other type of damage like twisting the paint. But with the slippage aspect for this type of polisher, if you press too hard on the tool, or hold the pad at an angle to the paint surface, instead of causing damage, the pad will simply stop or slow down pad rotation and pad oscillation. Thus, this is a very safe type of tool for people of all background experience.
The downside to a free spinning random orbital polisher
While some will argue this fact, (I no longer argue with people), anytime the pad is not rotating and oscillating, in other words, when the pad is merely vibrating or jiggling against the paint surface, you are not doing anything.
Or more specifically, you are not removing paint thus you are not leveling the surface and thus removing defects out of the paint. As I like to say, you are wasting your time.
Brain Drain
Another downside to a free spinning random orbital polisher is the brain drain that comes with running this type of tool for hours.
Let me explain. When running this type of tool, if you look at the back of the backing plate and the buffing pad, without some type of mark, it can be difficult to see if the pad is rotating/oscillating or stalling out. When you look at an unmarked backing plate and/or pad, what you see is a blur of motion.
To make it easier for your eyes to see and monitor pad rotation/oscillation, a technique professionals use is to somehow mark the backing plate and/or edge of the buffing pad. For light colored backing plates and pads you can use a black sharpie marker. For dark colored backing plates and/or buffing pads you can use a silver, white or gold marker.
Marking light colored backing plates with a black marker
You can also place some marks on the pads themselves.
For black or dark colored backing plates, use a light-colored marker like silver or gold. You can even use light colored automotive touch-up paint or even fingernail polish. Heck, I’ve even used White-Out, a white colored type of paint used in the old day to fix typing mistakes back before computers when the majority of people were using typewriters and paper.
Adding this simple mark will now make it easier for your eyes to look and see if the pad is rotating or not. Then the idea being, if you do in fact see pad stalling, (because the mark is not rotating or oscillation), you can try to remedy the situation by,
Sometimes making the above changes helps and sometimes it doesn’t help.
What does Brain Drain mean?
If you accept that marking the backing plate and/or side of the buffing pad as a fix to better enable your eyes to see and monitor pad rotation/oscillation, doesn’t this then mean that the ENTIRE time you’re going to buff out a car with this type of tool you MUST concentrate and LOOK at the backing plate and buffing pad to see in fact if the pad is rotating and oscillating or - stalling out.
A deeper look
Let’s say you’re going to do the paint correction to a 2014 Chevy Camaro that is totally swirled-out and filled with scratches. Let’s say you’re going to use a Porter Cable 7424XP. Assuming you don’t take any breaks, let’s assume you’re able to do all the paint correction to all the body panels, roof, hood, trunk lid, fenders and doors in approximately 4 hours. In my experience, this would be a minimal amount of time for a car this size and 6 hours would be more accurate for the average person with skill and experience using a Porter Cable 7424XP
Doesn't this then mean, you have to LOOK to SEE and MONITOR if the pad is rotating and oscillating for this entire time? Look, see and monitor for pad rotating for 4-6 hours? I call this Brain Drain. Constantly looking for pad rotation and monitoring how you’re holding the tool, the speed you're on and the curvature of any given panel drains your brain.
Most people don’t notice this until they read an article like this and then think about it. Maybe that’s you right now? Or perhaps you’ve watched a video or taken one of my detailing classes where you’ve heard me explain this aspect for using free spinning random orbital polishers.
It’s up to you and your style for doing paint correction but for me? I much prefer to use a gear-driven orbital polisher and think about what I want to think about as I buff for 4-6 hours versus being (practically) forced to look and see and monitor pad rotation/oscillation for 4-6 hours. It’s truly mind-numbing.
These types of tools (free spinning random orbital polishers), work best on large flat surfaces. As soon as you need to buff on a curved body panel, either concave or convex, because there will be different amounts of pressure applied to isolated portions of the face of the buffing pad - the pad will tend to stall-out. Because you cannot flatten out curved body panels, you’re stuck trying to maintain pad rotation/oscillation when buffing these portions of the body panel.
Outside of switching to a smaller free spinning random orbital polisher with a smaller backing plate and thus smaller pad, there’s not much else you can do to power through curved body panels without pad stalling. And even when you do switch to a smaller free spinning random orbital polisher with smaller diameter buffing pad to buff curved panels or thin panels - these types of tool are still inherently weak, and thus you will always have to combat pad stalling.
The walking-effect versus smooth sailing
Oftentimes you’ll see, read or hear someone describe what is called the walking-effect or the pulling characteristic for gear-driven orbital polishers. Just to note, rotary polishers also have this pulling effect. The majority of time I see someone reference the walking or pulling effect it’s in a negative connotation. Basically they are complaining about how the tool feels when they are using it.
What causes the walking effect?
When using a gear-driven orbital polisher, if you’re not holding the face of the buffing pad completely flat against the painted surface, any side of the pad that is getting more downward pressure will tend to grab the surface MORE and this will translate through the tool to you, (your hand and arms), as the tool pulling or trying to walk in a specific direction.
This feeling is called POWER. This type of tool has a LOT of power, just like a rotary polisher has a lot of power.
With a free spinning random orbital polisher, because there’s always some level of slippage taking place, the tools always feel SMOOTH and you’re running it over a surface. At least a lot smoother than the walking effect you can feel from a gear-driven orbital polisher. This at its core is LESS power.
When I see or hear someone complaining about the walking-effect, what I hear them saying is they don’t like all the power. Instead, they would like a weaker tool because it’s smoother.
Both opinions, some people like the power, and some people prefer a smooth feeling tool, are valid. And I learned a long time ago, my STYLE for doing paint correction is often times different than other people’s style for doing paint correction.
The way my brain thinks goes like this,
Detailing a car from start to finish takes a long time. If you count starting the day by washing the car, then claying the paint, then doing the paint correction steps, then somehow sealing the paint with a wax, synthetic paint sealant or a ceramic coating, it will take most people all day. We’re talking a long day, 8-12 hours.
And don’t forget all the little stuff like cleaning the wheels and tires when you wash the car, this takes around an hour. Later dressing the tires and cleaning the glass inside and outside as the finishing step.
Detailing a car from start to finish takes a long time. It takes a long time to go from start to finish to fully detail a single car - why would I want to do it in any way that takes LONGER? The answer is, I don’t want to do it in any way that takes longer, and this is why I opt for a gear-driven orbital polisher over any brand of free spinning random orbital polisher. Overall - it’s simply faster.
The upside to a gear-driven orbital polisher
Plenty of direct drive, or gear-driven power means the pad is going to oscillate and rotate no matter what the shape of the body panel, how you’re holding the pad to the surface, the speed setting, the type of pad - anything and everything. It just doesn’t matter because this type of tool is going to maintain pad rotation and pad oscillation no matter what -and this means you can plow through the paint correction step as fast as humanly possible without wasting time, energy or brain power and while also maintaining professional quality results.
The downside to a gear-driven orbital polisher
The walking-effect is a deal-breaker for some people and these types of tools also tend to be heavier, (only by a pound or two). The original gear-driven orbital polisher is the FLEX XC 3401 VRG and the MSRP is approximately $450.00 putting it out of reach for the weekend warrior, but the good news is the Harbor Freight version sells for $120.00. Of course the FLEX version comes with more bells and whistles, so let your own pocket book be your guide.
Summary
I know the above is a lot to chew through. I think you’ll find the video will fill in any gaps you don’t find via the above text and pictures.
Weekend Warriors
If all you ever plan to do is detail your own car or cars, chances are good you’ll probably only need a polisher once or twice a year. For this low frequency of use, a budget polisher makes sense. I own and have used extensively all the polishers in this article and I’m comfortable telling you, any one of these will be a great choice and will get the job done.
Future Professionals
If you’re just starting out but you’re toying with the idea of gaining experience and increasing your skill and comfort level doing machine polishing, I would still recommend one of these entry level polishers. Being under $200.00, it’s not a huge investment and if after buffing out a few cars you find you enjoy this type of work, you can always add more polishers to your arsenal.
If I could pick just one polisher out of the list?
Keep in mind, I’ve been detailing cars and specifically doing machine paint correction since the 1970s. As I write this article in 2024, that’s over 40 years of experience using pretty much all the common and popular polishers on the market today. In fact, I’ve done a lot of prototype testing for,
Because I do have a lot of experience, out of the polishers included in this article and the matching video, I would choose the Harbor Freight Forced Rotation Dual Action Polisher.
I like to get in and get out
I like to knock out my car detailing projects as fast as humanly possible while keeping my results professional quality. I don’t like having to look at the backing plate or pad constantly as I machine polish a car to see if the pad is rotating and oscillating, or just jiggling or vibrating against the paint. So for me, it’s a gear-driven orbital all the way.
By the way, if you want to read my full review for the Harbor Freight Forced Rotation Dual Action Polisher, which I tested out by buffing out a 1959 Rolls Royce Silver Cloud with a recent $50,000 dollar paint job, you can find it here,
Review: Harbor Freight Forced Rotation Dual Action Polisher
Final thoughts…
I hope this review of this collection of sub-$200.00 tools has helped you. I’m always available if you have questions. I would also strongly recommend taking one of my classes, especially if you find yourself to be the kind of person that learns better by doing, versus sitting in a chair looking at a PowerPoint presentation while the instructor drones on and on and on.
My classes don’t roll like that. We start early at 7:30am and the FIRST tool you will get hands-on time with is the rotary polisher and it only gets better from there. At the bottom of this article I’ll include recaps of my most recent classes. Click the links and look at the pictures. All you will see are happy people having fun working on actual cars and boats. We never use demo hoods in our classes because training on the real-deal, an actual car, has tremendously more IMPACT when it comes to comprehensive learning. You’ll also see, I tend to bring in really cool cars for you to train on.
Questions? Comments?
If you have further questions and/or comments, please add them to this article. You can also reach out to me via email, text or phone.
I hope to see you in a future detailing class!
Sincerely,
Chief Education Officer for Dr. Beasley’s
Mike@drbeasleys.com
Here are the most recent hands-on detailing classes at our training center in Stuart, Florida.
185 Photos from Mike Phillips’ 1-Day Auto Detailing Training Course (June 2024)
500+ Photos from Mike Phillips’ 3-Day Auto Detailing Training Class (May 2024)
600+ Photos From Mike Phillips’ 3-Day Auto & Marine Detailing Training Class (November 2023)
The above will take a little time to look at and digest. Enjoy!
Paint correction and ceramic coatings on a 1978 Camaro Z28 and a 1952 Hudson Hollywood Hornet Streetrod!
Extreme Boat Detailing!
Budget friendly
Under $200.00
Order of review
Pros
Inexpensive
Compact size
Cons
Vibrates your hands
Technical
8mm orbit stroke
6 speed settings
10’ Power Cord
120 Volts
5.7 Amps
5.6 pounds
My comments
Recommendation
Pros
Cons
Technical
8mm Orbit Stroke
6 speed settings
10’ Power Cord
120 Volts
4.5 Amps
5.5 pounds
My comments
- Rotary polisher
- Cyclo polisher
- Traditional orbital polisher or steering wheel polisher (because the handle is round like a steering wheel)
Rotary polisher
The Cyclo polisher
Recommendation
Pros
Why?
Cons
Technical
9mm orbit throw
6 speed settings
My comments
Recommendation
Optional
Pros
Cons
Technical
8mm orbit throw
6 speed settings
My comments
Recommendation
Pros
Zero pad stalling
Inexpensive
Cons
Technical
8mm orbit stroke
6 speed settings
25’ Power Cord
120 Volts
8 Amps
6.3 pounds
Forward bail handle
6” backing plate
My comments
- Provides constant speed control via the tachometer generator.
- Provides a soft, gradual start of the rotation of the electric motor that powers the drive mechanism.
- Controls the accelerator trigger switch.
- Provides restart protection after a power interruption.
- Provides overload protection.
- Monitors the temperature of the coil windings and turns the polisher off before damage can occur.
- Controls speed set by the variable speed dial.
Recommendation
- Free spinning random orbital polisher - Easiest, safest and inexpensive options.
- Gear-driven orbital polisher - Requires more physical strength high and low cost options.
- Gear-driven rotary polisher - The most powerful polisher for fast defect removal but can also cause damage.
- Gear-driven axial motion drum polisher - Unique design, the size and action of the tool requires more time investment to master. Not a practical first choice polisher for any beginner.
Cord or no cord?
IMPORTANT
The inner gear set
Outer gear set
- Tool speed
- Pad size diameter
- Pad size thickness
- Body panel shape - flat, concave or convex
- Body panel shape - large flat panels, thin long panels
- Dry pad versus wet pad
- Pad angle - whether the face of the pad is flat to the surface or on edge
Summary
Brain Drain
- Make sure you’re holding the pad flat to the surface.
- Increase the speed setting on the polisher
- Switch to a clean DRY pad
A deeper look
Summary
Weekend Warriors
- FLEX
- RUPES
- Makita
- Dynabrade
- Milwaukee
- DeWALT
Final thoughts…
Sincerely,
Mike@drbeasleys.com
