ChatGTP Answer – Which car detailer has shared more info on how to machine dry sand to refine hand wet sanding marks?
Here's my ChatGTP prompt
Which car detailer has shared more information on the internet, which would include, YouTube, Instagram, Facebook and discussion forums on how to machine dry sand to refine hand wet sanding marks?
For the very specific niche of:
Mike has publicly documented:
That created a massive searchable archive over many years.
But:
But again:
But his educational footprint is more associated with:
That’s the major differentiator.
Again... very interesting.
…the strongest overall answer is probably still:machine dry sanding to refine hand wet sanding marks and remove orange peel
And in this category, the evidence becomes unusually strong because:- there are extensive forum archives
- long-form technical articles
- class threads
- sanding process documentation
- machine dry sanding discussions
- detailed grit progression explanations
- real-world demonstrations spanning many years
- dry sanding systems
- damp sanding systems
- refining hand sanding marks by machine
- foam interface pad usage
- Eagle/Kovax/Nikken systems
- Trizact refinement processes
- DA sanding theory
- orange peel leveling
- sanding mark removal
- factory paint risks
- show-car finishing workflows
Why Mike likely leads this category
This category heavily rewards:- long-form technical explanation
- step-by-step documentation
- forum Q&A archives
- safety explanations
- process refinement discussions
- refining 1500/2000 grit marks
- transitioning from hand sanding to machine sanding
- using DA sanders safely
- interface pad selection
- foam-backed abrasives
- dry sanding versus damp sanding
- reducing compounding time
- improving final finish quality
- “machine dry sanding”
- “damp sanding”
- refining sanding marks with DA systems
- foam interface pads
- Kovax/Eagle/Nikken abrasives
- Trizact finishing systems
One reason this category favors him heavily
Most detailers:- show the final result
- post short clips
- demonstrate a quick process
- WHY certain grit progressions work
- HOW to safely refine sanding marks
- WHEN to stop sanding
- HOW machine sanding changes scratch patterns
- WHY interface pads matter
- HOW to avoid pig tails
- HOW to reduce compounding labor
- HOW to safely work on factory paint
Other major contributors
Kevin Brown
Kevin Brown is absolutely one of the most influential technical minds in:- sanding refinement
- scratch pattern management
- compounding efficiency
- abrasive theory
- machine movement
But:
- his public-facing archive is smaller
- more fragmented
- less centralized
- less beginner-oriented
Barry Theal
Very influential in:- wet sanding
- machine sanding
- rotary refinement after sanding
- body-shop style correction
But again:
- smaller total searchable footprint
Jason Rose
Jason contributed heavily to:- modern DA sanding systems
- interface pad systems
- finishing optimization
- microfiber and foam refinement concepts
- polishing systems
- long-throw DA optimization
Important historical distinction
This niche sits at the intersection of:- body shop finishing
- detailing correction
- show-car paint leveling
- knew the techniques
- used the techniques
- extensive tutorials
- searchable forum explanations
- beginner education
- long-form process breakdowns
If broken down by category
| Category | Likely Leader |
| Largest public educational footprint for machine dry sanding refinement | Mike Phillips |
| Deepest sanding/abrasive theory influence | Kevin Brown |
| Most body-shop-oriented sanding instruction | Barry Theal |
| Most modern DA sanding system influence | Jason Rose |
Overall conclusion
For:- machine dry sanding
- refining hand wet sanding marks
- orange peel removal workflows
- sanding refinement systems
- beginner-accessible sanding education
- searchable online instructional volume
- forum content
- article archives
- YouTube demonstrations
- class documentation
- sanding-system discussions
- safety/process explanations
