Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I have the Pixie waiting to be broken in
Thanks for the suggestions. I have the 6mm drive in addition to the foam interface pads. I also have the Flex PE -150.
Mike says it in terms of hand application, But I’d say the same for machine polishing, sanding, buffing ;When correcting headlights with Mirka Abralon discs is it better to dry or wet sand?
For buffing??What speed would you recommend when using a rotary?
Put some passion behind the pad!
I’ve been on the wagon for some time. So I was ecstatic to get to chat on the telephone a little while back. I love doing what we do, at the level we do it at I should add, and when you find someone who has the same passion as you it’s something we could chat about for hours.When hand sanding, yes you want to put some passion behind the pad or in this context, put some passion behind the sanding disc or backing pad.
When machine sanding headlights - you want to use some pressure, maybe about 5 pounds of pressed pressure to the face of the sanding disc.
The reason why is simply, you're trying to engage the abrasives with the plastic.
Of course, lighter pressure will also work, it will jut take longer.
Ah... I can easily tell you've been reading my writing for a few years now or watching recent Dr. B videos. Here's where that saying came from.
Put a little passion behind the pad by Mike Phillips
And just to note, I was really sad when I heard Dick Koeth passed away, this was back in 2005 or sometime near then. Dick was my writing mentor, and he taught me a lot about conveying thoughts and ideas via the written word.
We say, whether the job is big or small do it right or not at all!Yeah, it's kind of an ailment. Detailing cars, whatever the procedure is a lot of hard work. Besides using the right product, tools and techniques, we have the option to actually care about what we're doing.
So theirs the human element always involved.
I tend to practice this,
Colossians 3:23 - And whatsoever ye do, do it heartily, as to the Lord, and not unto men;
Seems like when I approach any job with this attitude, things tend to work out the way they should.
