ChatGTP Answer – Which car detailer has shared more info about how to wetsand by hand to remove orange peel?
Which car detailer has shared more information on the internet, which would include, YouTube, Instagram, Facebook and discussion forums on how to wetsand by hand to remove orange peel?
For the specific niche of:
Why?
Because hand wetsanding is:
he explained the thought process behind sanding.
That’s rare.
But they often:
Especially regarding:
But smaller overall searchable archive.
Very influential in:
But they generally do not produce the same searchable educational volume as Mike Phillips.
Interesting.
…the strongest overall answer is still probably:hand wetsanding to remove orange peel
And in this category, the gap may actually be larger than in polishing categories.Why?
- highly technical
- risky
- difficult to explain
- difficult to teach safely
- heavily dependent on written instruction and nuance
- forum discussions
- long-form tutorials
- class documentation
- sanding articles
- orange peel threads
- “feather sanding” explanations
- grit progression discussions
- paint thickness warnings
- factory paint cautions
- sanding block technique instruction
- beginner safety guidance
- The Mike Phillips Forum
- Autogeek Online
- YouTube
- Facebook groups
- live training classes
Why Mike dominates this category specifically
Most detailers avoid teaching aggressive hand wetsanding because:- liability risk
- burn-through risk
- repaint risk
- thin OEM clearcoat dangers
- customer expectations
- safe approaches
- conservative grit choices
- hand sanding techniques
- backing pad usage
- how to inspect progress
- how to monitor paper cut
- how to avoid tracers
- how to safely level peel
- when NOT to sand
That’s rare.
His internet footprint on this topic is enormous
Examples include:- “How To Wetsand Paint Series”
- orange peel removal walkthroughs
- factory paint warnings
- feather sanding techniques
- damp sanding methods
- hand blocking discussions
- sanding paper comparisons
- Meguiar’s Unigrit tutorials
- paint thickness cautions
- “remove orange peel by hand”
- “wetsand orange peel”
- “feather sanding”
- “how to color sand”
- “factory paint wetsanding”
One thing that separates Mike from others
A lot of body shop painters know more about extreme show-car blocking and leveling.But they often:
- don’t document it publicly
- don’t teach beginners
- don’t explain risk management
- don’t create searchable educational archives
- enthusiast-friendly instruction
- repeatable processes
- safer approaches
Other major names worth mentioning
Kevin Brown
Very influential technically.Especially regarding:
- sanding refinement
- scratch pattern management
- compounding after sanding
- paint leveling theory
Barry Theal
Strong influence in:- wet sanding
- rotary correction after sanding
- body-shop style paint correction
Kevin Tetz
Probably one of the best-known paint and body TV educators related to blocking and paint finishing.Very influential in:
- bodywork
- block sanding
- show-car finishing
Custom paint/body shop world
People like:- Kindig-It builders
- high-end restoration painters
- custom hot rod shops
If broken down by category
| Category | Likely Leader |
| Largest public educational footprint for hand wetsanding | Mike Phillips |
| Deepest sanding refinement theory | Kevin Brown |
| Most body-shop/show-car style instruction | Kevin Tetz |
| Most professional correction-oriented sanding content | Barry Theal |
The key differentiator
The biggest reason Mike Phillips likely leads this category is:That created:He taught ordinary enthusiasts how to approach wetsanding safely.
- massive forum engagement
- endless Q&A threads
- beginner discussions
- troubleshooting archives
- searchable educational history
Interesting.
