Clearcoats are thin by Mike Phillips
The majority of cars being manufactured today and starting since the 1980's use what's called a basecoat/clearcoat paint system. With this system, a clear layer of paint is sprayed over the top of the basecoat which is also the color coat or the layer of paint that has pigment in it. If the car has a metallic finish then the metallic flakes are also in the basecoat.
The basecoat doesn't offer any gloss or shine and in fact it's dull or matte looking after it's sprayed. The basecoat gets it's gloss, shine, depth and reflectivity by the spraying of the clearcoat layer of paint over the top of it. This is why if a person removes too much clearcoat when buffing and they expose the basecoat it will appear to be a dull round or oval spot on a body panel. The part of the paint system that adds beauty has been removed revealing the dull or matte basecoat layer of paint.
Just how thin is the clear layer of paint on a factory paint job?
The factory clearcoat on a new or modern car measures approximately 2 mils thin.
The average Post-it Note is around 3 mils thin.
watermark.php
What does this mean?
This means the factory clearcoat on a new or modern car is thinner than a post-it note. The next time you have a post-it note in front of you, feel a single post-it note between your fingers. Like this...
watermark.php
This experience will drive home the point as to just how thin the clear layer of paint is on modern car with a factory paint job.
It should also drive home the importance of using the least aggressive pad, product and even tools to get the job done.
When I say, get the job done, the context of this usually means someone is buffing out a car to remove paint defects like swirls, scratches, water spots and oxidation to make the paint and thus the car look better.
By using the least aggressive products you "get the job done" while leaving the most paint on the car to it will last over the mechanical service life of the car.
If you're working on your own cars and you're reading this you're already ahead of the game by reading the AGO forum and probably being a member so you can ask questions and get help.
If you're working on customer's cars take a professional approach as a service to your customers.
If you're reading this and you're going to do the work yourself or hire a detailer then do some research and make sure you hire a detailer that knows this type of stuff because the factory clearcoat on your car is thin.
When the clear layer of paint become too (from improper detailing) or if it's not properly and regularly washed and waxed one result can be clearcoat failure.
Clearcoat failure is where the paint flakes and peels off. Your car will look like it has a rash. Like this,
My friend Paul owns a body shop. He only does professional quality repaints. I asked him if someone brought him a car, for example an average sized passenger car and it needed ZERO body work. It only needs new paint. How much on average would he charge?
He said about $3000.00
Now this is for a high quality paint job to a mundane passenger car that needs no body work. Of course you can get a less costly paint job but instead,
Learn to take proper care of your car's paint while its still in great shape.
Only hire qualified detailers to do the work for you but - do hire them and have your car washed and waxed on a regular schedule.
