Headlight Correction Mirka Sanding Discs by Mike Phillips
At our most recent 1-day class, we covered how to machine wet sand headlights using 3" Mirka Abralon Sanding Discs. After the class, a number of people have reached out to me asking where I purchased the 3" Mirka sanding discs. Below are links.
3" Mirka Foam backed 500 Grit Sanding Discs
3" Mirka Foam backed 1000 Grit Sanding Discs
3" Mirka Foam backed 2000 Grit Sanding Discs
An interface pads helps with both sanding disc rotation plus enables the face of the sanding disc to conform to curved surfaces.
3" Foam Interface Pads
