How to edge a panel via dry sanding using the 3D Dry Sanding System!
In this video, Mike Phillips shows you how to *edge a panel* using the 3D Dry Sanding System. Edging a panel is where you do all the sanding next to edges or raised body lines using smaller sanding discus on smaller orbital sanders to knock down any orange peel, dieback, shrinkage, graininess or other surface textures.
Precision Sanding
Smaller sanding discs and smaller sanders enable you to do PRECISION SANDING because they are easier to control and guide over the panel. By using smaller sanding discs you avoid accidentally sanding on top of an edge or raised body line that simply requires more time, focus and experience to do with larger 5" and 6" sanding discs and sanders.
After you *_edge a panel_* you can then switch over to a larger sander to knock out the middle section of the panel. Because the difficult areas are already sanded, this technique enables you to knock out the larger sections faster and easier as you no longer have to worry about being PRECISE with the sander to avoid sanding on top of edges and/or raised body lines.
More videos in this series
Here's the other videos in this series of videos for the 1969 Plymouth Roadrunner Dry Sanding Project
Products used
3D 5mm Brushless Electric Sander
ACA Flex P1500 3" Orange Sandpaper Disc - Box of 50
ACA Flex P2500 3" Orange Sandpaper Disc - Box of 50
ACA Flex P1500 6" Orange Sandpaper Disc - Box of 50
ACA Flex P2500 6" Orange Sandpaper Disc - Box of 50
Flat Micro Hook Interface Pad - 3" - 2 Pack
Flat Micro Hook Interface Pad - 6" - 2 Pack
FLEX Cordless PE14 Rotary Polisher
FLEX XC 3401 VRG 120/US Forced Action Orbital Polisher
FLEX PXE 80 12.0-EC Multi-Set Polisher
3D EZ-SWITCH Adapter
3D EZ-SWITCH Backing Plates
3D 8" Yellow X-Cut Lambswool Pad
ACA 510 Premium Rubbing Compound
Want to learn how to detail cars or boats like a true PRO?
Mike teaches the most hands-on detailing classes on planet Earth and he PROVES it with MORE PICTURES showing what his classes are actually like. NO OTHER detailing company, instructor or class shares this many pictures showing what you’re actually going to do when you take their class.
551 Pictures that PROVE how hands-on Mike Phillips Detailing Classes Are! No Chairs and NO SITTING!
Click here to sign-up, find out the dates or get more information
Questions? Call Mike during normal business hours EASTERN time at: 772-312-9712
Or shoot him an email or text to: mike.phillips@3dproducts.com
Precision Sanding
Products used
