KirbyT
Mike,
Reaching back into your past product experiences with 3D Coating and time with Autogeek products, can you give some thoughts on this problem of a solvent dripping onto a ceramic protected surface.
I used the Wolfgang Exterior Trim Sealant on the top cap trim on the bed of my F150. It always gives the trim plastic a nice black layer of protection for a short term under the sun and heat. I was washing the truck bed and noticed the 3D coating (older version) was dead below a section of the trim. No water beading was showing but the areas around it did still bead water. My guess is that the 'sealant' dripped down and covered the coating giving the impression it was dead.
I tried to wash that again and use an APC, water spot remover, and pH neutral soap. While it helped nothing restored the water behavior like it was. Is there a solution or method of ways to remove the outer layer from the ceramic if it does exist?
Just curious as this might happen to any ceramic coating. Just not sure the proper steps to uncover and restore the ceramic short of reapplication.
Kirby Thomson
dba MyGuy Auto Detailing
A MP's alumni!
Kirby Thomson
A MP's alumni!
