May 2nd & 3rd Detailing Class - Includes Rotary - Orbital - Wet Sanding by Hand - Dry Sanding by Machine $1,295.00 - Real Cars - No Chairs!
Here are the 3 Primary Topics you will learn on the first day of class
  1. Show Car Detailing - Multiple-Step Paint Correction Process - Starting with Rotary Polishers.
  2. Two-Step Paint Correction & Ceramic Coating - Starting with Orbital Polishers.
  3. One-step Ceramic AIO - Budge Detail - Daily Driver Detail - Your choice of any of the $50,000.00 worth of polishers in our shop.
And if you're researching car detailing classes, LOOK to see if they show you what you're actually going to TRAIN ON. No one else does this until they start copying my format. Here's the training car's I've confirmed for this class.
Saturday Paint Correction & Ceramic Coating Training Cars - Rotary Polishers & Orbital Polishers
Topic 1 - Show Car Detailing - Multiple-Step Paint Correction Process - Starting with Rotary Polishers
First tool, first thing in the morning you will be training to use on these cars is the ROTARY POLISHER!
2006 Ford Mustang - HAMMERED BLACK PAINT!
1965 Corvette Stingray - Holograms - Swirls - RIDS
Topic 2 - Two-Step Paint Correction & Ceramic Coating - Starting with Orbital Polishers.
For this second set of cars, the first tool you will train to use on the below cars is GEAR-DRIVEN orbital polishers. We have FLEX, Harbor Freight and RUPES for you to test out.
2007 Ford Shelby Mustang GT 500
2006 Corvette Z01 - Black with lots of swirls
Topic 3 - One-step Ceramic AIO - Budge Detail - Daily Driver Detail - Your choice of any of the $50,000.00 worth of polishers in our shop
For this THIRD topic you will learn, you can choose from either gear-driven orbital polishers or FREE SPINNING RANDOM ORBITAL POLISHERS. We have Griot's Garage, Harbor Freight, corded and cordless FLEX and RUPES polishers to choose from. Use them on real cars and make up your own mind, which tool is your favorite.
2022 Genesis G70 - Holograms- Swirls- Stains
1993 Mazda Miata Eunos Roadster Vspe
Sunday - Removing Orange Peel - Sanding Class plus Rotary Polishers
On Sunday, we start in on sanding and buffing. Here's the process you will train to use.
  1. Wetsanding by hand.
  2. Machine sanding dry
  3. Rotary polishers
  4. Orbital polishers
  5. Ceramic coating
1968 Camaro Pro Street
1932 Ford Roadster Streetrod
Here's the primary tools you will learn to use
FREE BONUS CLASS on FRIDAY (the day before the actual class starts
Sub-surface glass polishing to remove scratches out of glass
For this we will have a 1967 Cadillac with WIPER SCRATCHES in the windshield.
1967 Cadillac Eldorado
Clear Plastic Window Polishing
For this topic, we will be removing the rub marks, scratches and oxidation out of the back window on the Miata that will be here for the Saturday paint correction class.
1993 Mazda Miata
Here's link to get singed up - discount for multiple people
Click here to save your space for the May 2nd & 3rd Car Detailing Class
Need help getting here? I've done all the legwork for you!
Airports - Hotels - Restaurants - Plus things to do in Stuart Florida!
Questions? Shoot me a text or give me a call: 760-515-0444
No chairs. Zero sitting. 100% You train on real cars, usually really cool cars!
The first day starts with how to use the rotary polisher and this is key because on the second day, after wet sanding and machine dry sanding a custom paint job, you're going to need your rotary polisher skills to remove 100% of the sanding marks.
Class Descriptions
Topics Covered on Saturday
Starting at 7:30am sharp, you will learn 3 primary topics plus more topics depending upon the needs of each training car.
1. 3-Step Paint Correction & Ceramic Coating - Also called Show Car Detailing. This would be your High-End Exterior Detail Package.
2. 2-Step Paint Correction & Ceramic Coating - if you detail for money, this would be your Mid-Range Exterior Detail Package.
3. 1-Step Paint Correction & Ceramic Coating - This is your entry level, Budget Exterior Detail Package.
Besides the above, we cover as many topics as were' able depending upon the needs of the training cars,
  • Topical Glass Polishing – all cars
  • Black Plastic Trim Restoration
  • Headlight correction
  • Rock Chip Repair
  • Pad cleaning with pad washers
  • How to do a proper Test Spot – all cars including sanding cars
  • Paint Thickness Gauges
  • Surface evaluation with Detailometer
  • How to use inspection lights
  • How to tape-off and protect trim and delicate surfaces
  • And more – depends on time and needs of car
As you can see, these are very intense and busy classes. Please wear comfortable work clothes and shoes
Topics covered on Sunday
On the second day, we bring in cool cars with custom paint jobs with plenty of orange peel and unwanted surface texture. You will learn how to sand and buff a car to remove orange peel and create a show car finish. With most other classes, you only get to sand on demo hoods or test panels. We bring in the real deal because there's more to learn when sanding an actual car than a flat surface, waist high.
  1. Wet Sanding by Hand using Nikken Electronics Grade Finishing Papers to level Orange Peel.
  2. Dry Sanding by Machine using Eagle Abrasives by KOVAX and FLEX Cordless Orbital Sanders.
  3. Rotary Polishers - You will learn American Style Rotary Techniques - (faster and more efficient than European Style).
  4. Gear-Driven Orbital Polishers - Learn how to master the BEAST!
  5. Free Spinning, Random Orbital Polishers - Learn how to maintain Pad Oscillation/Pad Rotation.
  6. How to prep the paint for a Ceramic Coating.
  7. How to install a Ceramic Coatings.
The second day is more intense than the first day, so keep that in mind and get to bed early on Saturday night after the Dr. Beasley's sponsored Meet and Greet Dinner at Fresh Catch.
General Info
  • No chairs
  • Zero sitting
  • Zero PowerPoint presentations
  • We start at 7:30am SHARP
  • Class goes until all topics and cars are completed - around 5:00pm
  • Depending upon size of class you will train on 4 to 8 cars over the course of two days
  • Framed Certificate
  • Dr. Beasley's T-shirt
  • $75.00 Store credit
  • Donuts and coffee in the morning (arrive by 7:00am)
  • Pizza and/or Sub Sandwiches provided for lunch.
  • Bottled water provided all day.
  • Dr. Beasley's sponsored Meet & Greet Dinner at Fresh Catch Seafood Grill
These are the most documented classes and the most intense hands-on classes on planet Earth.
Price for 2-day class: $1,295.00
The majority of people that take this class are serious and are travelling here from other states or other countries. To make travelling and staying here easy, I've put together all the information you need.
Thank you for signing up for one of our detailing classes here at Dr. Beasley’s O. R. - We do everything we can to make it as easy as possible to get here and have a great time! This includes getting you accurate information about the nearby airports with the correct airport codes, the closest and best hotels to stay at while you're here and also the best place to get great FRESH seafood or any type of cuisine you prefer.
Dr. Beasley's O.R.
Airports
The closest and thus fastest and easiest to get to Dr. Beasley’s O. R.
West Palm Beach Airport - Airport Code: PBI
Approximately 30 minutes from Dr. Beasley's <--Closest airport to Dr. Beasley’s O. R. Straight shot on I-95
Fort Lauderdale Airport - Airport Code: FLL
Approximately 2 hours away from Dr. Beasley’s O. R. - Straight shot on I-95
More Florida Airports - Further away from AutoForge.net
Miami Airport - Airport Code: MIA
Approximately 2 hours and 30 minutes away from Dr. Beasley’s O. R. with great traffic conditions - Straight shot on I-95
Orlando Airport - Airport Code: MCO
Approximately 3 hours away from Dr. Beasley’s O. R. with great traffic conditions. - Must take multiple highways and/or toll roads but doable.
Hotels
Note: Pricing is dynamic and varies by dates.
These first two hotels are the closest to our training center. They are literally right down the road.
Courtyard Stuart
7615 SW Lost River Road
Stuart, Florida 34997
772-781-3344
There is an in-house restaurant, Starbucks and full bar. The Cracker Barrel, McDonald's and Chevron Gas Station/Mini Mart are right next door.
Holiday Inn Express - Stuart Florida
7900 SW Lost River Road
Dunkin Donuts and La Forchetta - an Italian Restaurant are both right next door in the same parking lot. I highly recommend La Forchetta - superb, authentic Italian food. Wendy's is also on the entrance road.
Continued
All other hotels are going to be a few miles down the road but still and easy drive on Kanner Road.
Comfort Suites Stuart-Hutchinson Island - (The name is misleading as this hotel is smack dab in the middle of Stuart, not on Hutchinson Island)
3423 SE Federal Highway
Note: I have not stayed here but past class students that have all say it's really nice and more affordable than the Courtyard Stuart. There is no in-house restaurant or bar.
Quality Inn Downtown Stuart
950 SE Federal Highway
Note: I have not stayed here and have no info about it. It is right next door to a very popular local restaurant Flanigan's, which does have great food and drink.
Restaurants
Stuart has a LOT of great restaurants close by and if you like great seafood that's fresh, then there are plenty to choose from. The below are some of my favorites.
Close to Dr. Beasley’s O. R. and the above listed hotels
Fresh Catch Seafood Grill - Seafood - One of my personal favorite for seafood - we normally hold our Meet-N-Greet at Fresh Catch. The owner's two sons are local commercial fishermen, thus the name fresh catch
1411 SE Indian Street
La Forchetta - Italian - VERY authentic Italian food - highly recommended if you like Italian food. Small size, best to make reservations.
7820 SW Lost River Road
Flanigan's - Award winning ribs, chicken wings and burgers
Stuart, FL 34994
772-220-0039
Anthony’s Coal Fired Pizza & Wings - Amazing wings and pizza
2343 Southeast Federal Highway
Stuart, FL 34994
772-287-7741
A tick more of a drive but incredible places with great food
Stuart Boathouse Restaurant - Bar - On the water - great view, great food and drinks - in old downtown Stuart, parking can be tight during peak hours
49 SW Seminole Street
Dolphin Bar & Shrimp House - On the water - 2 bars - amazing food
1401 NE Indian River Dr
Jensen Beach, FL 34957
772-781-5136
Kyle G's - Seafood - Steak - Chicken - On the water with amazing Ocean view
10900 S Ocean Drive
Hutchinson Island, FL 34957
772-237-5461
Talk:House - Incredible experience - amazing seafood as well as traditional American cuisine
514 NW Dixie Highway
Stuart, FL 34994
772-692-3662
Things to do around Stuart!
A lot of people attending our classes bring their families and are looking for fun things to do with their kids while mom or dad are at the class. Below are a few resources to get you started.
Bathtub Beach in Jensen Beach - Very close to Stuart
1585 SE MacArthur Blvd, Stuart, FL 34996
This is a easy to access beach with an artificial reef separating it from the ocean, which acts to keep out sharks for a family friendly and kid-safe ocean swimming experience. I'm a distance swimmer myself and always feel safe when I go swimming at Bathtub Beach.
View Webcam
Jensen Beach
4191 NE Ocean Blvd, Jensen Beach, FL 34957
View Webcam
Chastain Beach
1213 SE McArthur Blvd.
Hutchinson Island Beaches, FL
Guarded, seasonally. Natural beach. Bathrooms, showers. Is between the House of Refuge and Bathtub Reef along A1A.
Hobe Sound - (Hobe is pronounced HOPE - you say the letter P instead of the letter B)
Hobe Sound Beach, Jupiter Island, FL 33455
View Webcam
Florida Oceanographic Society
Florida Oceanographic Society is a non-profit organization founded in 1964 with the mission to inspire environmental stewardship of Florida's coastal ecosystems through education, research and advocacy.
Florida Oceanographic Coastal Center is a 57-acre marine life nature center located on Hutchinson Island in Stuart, FL situated between the Indian River and the Atlantic Ocean. As a leading state and nationally recognized environmental organization, Florida Oceanographic offers educational programs to people of all ages and conducts research and restoration programs that lead to healthy coastal ecosystems.
Check out LIVE FISH via the FISH CAM!
Questions? Help? Recommendations?
We're different, we've always been different and we document it!
Unlike all the other classes on planet Earth, we show you the cars you'll be training on BEFORE the class.
If you look at ANY other class, all you'll see is a picture of a dude running a buffer over the hood of a car, next to the picture is a bulleted list sharing the topics you'll get to learn, BUT NO PICTURES of the actual cars for this class. And the reason why is because in most cases, there are no cars. If you get to use a polisher or sand at all, it's going to be on a Demo Hood or a Test Panel. If you're really lucky, they may have a rental car or something from the parking lot. So do your research so you're not disappointed with the class you choose.
Saturday Paint Correction and Ceramic Coating Training Cars
Below are training cars confirmed for this 2-day class.
Car to be confirmed and added here
Sunday Wetsanding Training Cars
More cars to be added as they are confirmed.
Wet Sanding by Hand
There's a number of ways to sand car paint to flatten orange peel. In our classes, we start with the most important sanding skill and that's how to correclty HAND WET SAND. For this we use the Nikken Finishing Papers, which are an electronics grade of sandpaper, much higher quality than automotive wet/dry sandpapers. We also use medium density soft blocks, not hard blocks and you'll learn why in the class.
Machine Dry Sanding
After you learn how to wet sand by hand, the next skill you'll learn is how to machine dry sand to refine the hand sanding scratches to a finer or more shallow depth that will be faster, easier and safer to remove using a rotary polisher. For this you'll train using sanding discs from Eagle Abrasives by KOVAX and FLEX cordless DA Sanders, including the FX3411 and the PXE-80.
Here's a recent example showing these sanding tools at one of our past classes.
How to Wetsand Cut and Buff - 1949 Chevy Fleetline Streetrod
Here's another recent class - see what I mean when I say we DOCUMENT our classes? It so we can show you what our classes look like so you can shop around to make sure you're taking a great class, not a class you'll regret after the fact.
Removing Orange Peel - Full Process Video - Dr. Beasley's 2-Day Detailing Class
All our classes will sell out. So make your travel plans and secure your space.
Click here to sign-up for the May 2-Day Class!
Just confirmed these two cars for the Sunday portion of the class - removing orange peel via sanding
