Paint correction
Mike, the sanding discs can I use a rotory or do I need a specific polisher. I Have D.A.s
Thanks Nick
When you use a rotary to sand it's no longer callled sanding - it's called grinding.
You should use any short stroke DA polisher and an interface pad. Harbor Freight also has an interface pad.
The HF stuff is all industry standedard 6" - but if you for example, a Porter Cable with a 5" backing plate, just cut the interface and sanding discs to fit or use as they are. It's not rocket science.
Getting ready to spray again!
I am practicing on a piece of metal to get the feel down !:)
