Setec Astronomy
I've had an early generation GG 3" polisher forever (I forget whether it's the first or second generation). This is an underwhelming machine, but I've found it useful for sanding headlights (which I haven't had to do for a while). When the iBrid Nano came out, it was interesting, but not something I felt I needed. I was excited when Flex came out with the PXE-80, but disappointed it didn't have a trigger.
In the meantime, GG came out with their version of the "PiXiE", and it had a trigger, but it was $400, and since like Mike Phillips, I like to use my Flex 3401 and can use the edge of the pad to get into a lot of tighter spots, I haven't really felt the need for a mini polisher. Besides, I hardly do any polishing anymore, heck I hardly do any washing anymore, but life is life.
My newest car sat on the dealer lot for a long time, and I guess collected a bunch of tree debris under a piano black valence panel, which seems to wash out every time it rains or I wash the car. I guess at some point I used a too-aggressive (for piano black) brush trying to get debris out from between the valence panel and the paint, because last time I was washing the car I noticed a bunch of marring to the piano black in that area.
This was bugging me so I went back to look at the SPTA Cordless Mini Polisher I had looked at some time ago on Amazon. They had a $45 off coupon, and, well, I just couldn't resist for $115 for the whole kit. It comes with the polisher, charger, two batteries, a 3mm and 12mm DA eccentric, 4 backing plates (more on that later), and an assortment of foam, MF, and wool pads in 1", 2", and 3" sizes, some brushes, and a fitted carrying case (which doesn't have any room for the pads).
The eccentrics screw on, unlike what I've seen that some of the others have a quick release, and the 3mm eccentric has a smaller output thread than the 12mm, so the 1" backing plate can only be used for rotary or 3mm, there are (2) 2" backing plates, each with a different thread size, so you can use 2" pads for rotary, 3mm, or 12 mm, and the 3" backing plate can only be used in 12mm DA mode.
First impressions are...wow this thing is really heavy! The weight seems to be in the middle of the unit, between the trigger and the head, where the motor is. Hopefully that means it will have plenty of power. It seems smooth and quiet just running it with the backing plate and eccentric that was installed. In the pictures, the battery looked very similar to the Milwaukee 12V that I have for some other tools, but in reality it's quite different. The batteries are quite light and don't really do anything to balance out the weight from the motor.
Not sure when I'm actually going to get to try this out, but here's what it looks like (Amazon picture):
