Mike,
Thanks for the detailed info, I greatly appreciate your time and wealth of experience. I have not tried the 3D products yet, and since I just purchased the McKee's Graphene DGCS, I will be using that for quite a while.
I recommended the SPEED to use as a "polish" not an LSP or Last Step Product. You would use this if moving forward you found any type of paint defects. Use the SPEED as a polish and then top with the McKee's Graphene GDCS.
SPEED is an AIO but I often use it like a polish because it will do everything a polish will do plus provide short-time protection. Thus the reason to top with something as a "dedicated LSP" will provide longer lasting protection than any AIO.
But - if you don't have any swirls, scratches, water spots or oxidation - then the you don't need a polish or an AIO - just use the McKee's Graphene GDCS.
I was going to ask you if you recommend using the Bead it Up over the top of the McKee's Graphene DGCS, or use McKee's Graphene detail spray (to stay in same family). But I just looked at the product description and see it is much more than just a detail spray, it's an actual spray on sealant., so I assume it isn't necessary over the top of the McKee's Graphene DGCS.
I haven't used the McKee's Graphene detail spray enough to have a real-world opinion. I've used a lot of the Bead It Up. You're correct in that it is a dedicated polymer sealant but I like to also use it as a spray detailer as long as I'm only refreshing the shine and slickness or the car only has light dust, fingerprints and/or smudges.
Nice product. It's everything everyone hoped a similar, popular product would be.
I am sure life will be much easier on my regular drivers if I were to move on to ceramic, I just need to decide on which one to use. The McKee's Pro Coat 2.0 seems like an easy process.
All the Best,
Bill
Ceramics have changed car care and the detailing world for the better.
